Create or edit a form in JIRA Server instance
Joao Carriço April 22, 2022
Hello community,
I have a request to make our tickets with a certain format (inputs to be provided) . I've seen that there are "Forms" for this need.
Two questions:
1) Is it possible to create "Forms" in JIRA Server Instance as it exist to JIRA Cloud
2) Can these "Forms" be blocking? Ex.: If there are no attachments (Photos), the ticket should be blocked.
Thank you in advance
A_ Boehme
To answer your second question: Yes, you can set an attachment as required. You don't even need a form for that, you can simply do it when configuring the request type with the form.
Best
Almuth
Sebastian Krzewiński
Hi @Joao Carriço
It is possibloe but in Jira Service Management like it was in your link - https://confluence.atlassian.com/servicemanagementserver/setting-up-request-types-939926357.html
Forms/Request types are not available for Jira software/Jira Core. Jira Service Management is a seperate product for this.
Seba
Joao Carriço April 27, 2022
Hello @Sebastian Krzewiński ,
thank you for your prompt reply.
I'm going to check if we have this module at CERN.
João Carriço
