@Anna-BigPicture Hi Anna, please could you provide some clarity on the below query I have.
Does BigPicture provide a status on the % of tasks in the 'created' state similar to the 'to-do', 'in progress' and complete shown on the below screenshot.
Thank you.
Yes, if your workflow contains an item "Created," then BigPicture will display a percentage value for this status as well.
The above makes sense, however, if you see below the hierarchy does contain 'created' but still does not provide the % at the top level where the 29.6%, 17.3% and 53.1% are presented?
Thats great thank you.
Is it possible to change the 'overview' screen to provide a similar breakdown?
