Creating Epic level issue type
Shirley Jhirad
Is there a way to create additional customized issue types that have the same behavior as an Epic?
Shirley
Chander Inguva
December 16, 2015
Hey Shirley,
                   If you are looking for Higher level, you can try Portfolio for JIRA plugin which has Initiatives/Epics/Story which when configured and pushed  into JIRA you can have Sub-Task feature as well
If you are only looking in JIRA proper then the answer is "No" to your question.
Regards
Chander Inguva
Phill Fox
December 16, 2015
Hi Shirley,
Unfortunately not as Epic is hard-coded in to the system along with versions.
Phill
