Creating Issues using the API with a Organization API token
Pim van den Broek May 30, 2024
I'm trying to create a solution where I can automatically create issues in our jira cloud instance, but without using a personal account (employee might leave etc).
I've created an organisation api token, but when I try to use that, I get empty responses (i.e. listing projects).
Is there no other way to create Jira issues without using a personal api key?
Kalyan Sattaluri
May 30, 2024
Hello @Pim van den Broek
Org API Tokens are to manage Org properties of the Jira. Its not a super admin role which lets you create issues etc.
I think you are looking for a "service account" type of role and its token.
Unfortunately, I dont think there is such an option.
People just create a dummy user, assign the user appropriate priveleges across projects, then log into Jira to generate token as a user, and then designate this user as service account and use its credentials for API calls go forward..
Hope it helps. Thanks.
*Above is my understanding.
Thats what I thought too. Using a dummy user for automation is more a workaround than a solution in my opinion.
But if there is not other decent solution, that will have to do for now. Thanks for your input!
Like Harley McKenzie likes this
Mohanraj Thangamuthu
May 30, 2024
Hello, Good day. User should have "Create issue" permission on the project and a valid Jira software license for issue creation. Thanks
I wasn't talking about a user api token, but about Org API Tokens. And unless I'm missing something, you can't add permissions to those.
Learn more
