Sign up Log in
Creating a Project template to move across Sites
Richard Esteviz September 12, 2023
Is it possible to have a full workflow made in one site or ORG and make a template of it to move across to another site /org that's under the same enterprise account. So it would have org admins that are shared on both to transition the move.
API or CLI options are ok.
For Context Full workflow includes A portal site form on JSM that can pull in confluence pages and a board with workflow conditions in Jira software. Workflow conditions that allow the tickets to proceed based on whether conditions are met.
No connect to the original board or portal is needed as its hoped to just reduce time for creating the workflows and this will connect a new JSM portal to an existing Jira software Board and confluence pages.
Cassie the Jira Mechanic
September 12, 2023
@Richard Esteviz Yes! You can actually export your workflow and import it on the other site.
Open up your workflow to edit it. Then select Export.
Here is more detailed documentation:
Import and export issue workflows | Atlassian Support
I hope this helps! If so please Accept the answer so others know it works!
Richard Esteviz September 14, 2023
For the point when I have to put this workflow on a public space for the Binary URL for marketplace. What is a preferred or even just an option for the location to be for public access.
Will an open google drive location do or will it need to be something else?
Given this is just to move a workflow there has to be an option that wouldnt require building a server to hold this template.
