Creating a dashboard using Labels
Julie Glass January 9, 2023
Is is possible to create a dashboard to track labels? We want to see where our resources are being spent.
Julie
Dave Liao
@Julie Glass - hi Julie!
You have two dashboard gadgets that may help:
  • Use the Labels gadget to visually see labels in use for a given project, or set of projects.
  • You can also use the Issue Statistics gadget, and query on the Statistic "Label" to see a breakdown.
Dave Liao
That said, I would convince your teams to use Components or custom fields where possible. 🙃
Like • Udhaya Karthick likes this
Julie Glass January 10, 2023
Hi Dave,
Thanks for the quick response. With the label gadget, is there a way to view a time range? Same with the statistics gadget.
Julie
Meghan LaClair January 10, 2023
Disclaimer: Marketplace partner
Hi @Julie Glass - this is something that is on our immediate roadmap - we would be willing to consider incorporating your feedback if you are open to sharing your requirements.
Dave Liao
January 10, 2023 edited
@Julie Glass - With the Labels gadget, I don't think so?
With the Issue Statistics gadget yes!
That worked! Thank you
Dave Liao
@Julie Glass - if my answer helped you (and answered your question), be sure to click "Accept answer" 😀
