Creating issues out of the sprint column
Ofir Oxenberg
On my active sprint board i have the option to create issues out of a column directly.
Looks like this
seems like it is connected to the "blocked" status, cause every time I move the status in the column board settings, the option moves to that column.
But this option is not available to any of the other statues.
Can I control in which column this option will be available?
Thank!
2 accepted
Karan Sachdev
September 29, 2025
Hey @Ofir Oxenberg
From the details, it appears that "Blocked" is the first status in your workflow. The new work item will be created in the first status, and then can be moved to other statuses as per the workflow configuration.
Shalini Pradhan
September 29, 2025
Hello @Ofir Oxenberg ,
Good day! Welcome to Atlassian Community :)
The reason why you see the issue create option on the board for the blocked status, is because it must be the first status of the workflow the project is using.
There are certain factors that need to be checked in order to make sure the 'create' button is visible for all statuses on the boards.
  1. The user should have permission to create issues in the concerned project.
  2. The board column has not reached its maximum issue limit.
  3. Issue type workflow includes valid transitions to all statuses in the column.
  4. Workflow should not have direct transitions only. It should have global transitions to the column's status(es) without any validators, conditions, or transition screens.
  5. The initial workflow transition has no condition or transition screen.
  6. Board filter JQL is simple and easy to evaluate
More details in this document: Fix "Create" Button Visibility in Jira Company Managed Boards
Thank you!
Carl Bidwell
September 29, 2025
You can’t actually create issues straight from the Sprint (active board) column in company-managed projects, that option only exists in team-managed ones.
A couple of workarounds you can try:
Use the Create button and make sure the Sprint field is available, so you can drop the issue right into the active sprint.
Or just create the issue in the backlog and drag it into the sprint column afterwards.
Here’s a related discussion on the same forum that might help: https://community.atlassian.com/forums/Trello-questions/Why-are-my-Trello-boards-being-moved-to-a-workspace-for-a-14-day/qaq-p/1764787
Ofir Oxenberg
Thank you!!
