Creating sample project in new JIRA Software?
Mike Tocci
Hi all,
We are using JIRA Software (cloud) service with the new navigation experience. This was updated a few months ago (December 2017?). I used to be able to create a new project with sample data, but now the Create Project button only allows template selection that creates a new blank project.
Sample projects are useful for training and brainstorming new processes. Is this functionality coming back?
Mike
14 votes
Marin Mamic
February 23, 2018
The functionality is there, just not where you (or anyone for that matter) would expect it. You can reach it from any existing board settings where you can select "Create new board". It will then give you an option to "Create a Scrum board with sample data" and also create a new project with it.
Mike Tocci
Thanks @Marin Mamic! I knew I was missing something.
Like • Matthew Winchell likes this
Marin Mamic
February 23, 2018
Don't mention it. I'm glad i could have helped. I had the same issue myself.
uptownaravi
May 30, 2018
Thank you for the answer @Marin Mamic, was searching for this while trying out Jira cloud.
Emily Jarvis
June 4, 2018 edited
***Updated*** I found the answer. You have to go into an existing project, click on the backlog, then the 3 dots in the upper right corner and "create board"
@Marin Mamic For the life of me, I can't find existing board settings. There is the dashboard, etc. How do I get to "Create new board"?
Like • 6 people like this
Ijeoma Ekeh
July 20, 2018 edited
@Emily Jarvis It's been awhile, so you may have already found the answer.  But, to get to "Create new Board", go to the magnifying glass in the left side navigation bar and search the term "boards".
Select "View All Boards", and in the next screen, go to the far, upper right where it says "Create new board".  There, you will be able to create a new board, with sample data.  It will also create a new project where the board lives, unless you choose to add it to an existing project.
Like • 2 people like this
Emily Jarvis
Thank you!!
Like • Ijeoma Ekeh likes this
Liz_Pat
Mystery solved at last. Thank you!
Mike Sheehan
October 21, 2019
One year later - thank you :)
Steve Terelmes
But the option is still lost for Jira Service Desk projects (which don't use scrum boards). I have found sometime that even when an option has been removed in Jira, the old URL will still take you there. Has anyone found the ability to create a JSD with sample data anywhere?
Sam Ayres
Oh hey Steve from two years ago!
Like • David VanDyke likes this
Dheeraj Kumar Aggarwal
I have written a step by step article to solve the issue of generating sample data with Jira Cloud.
https://optimizory.atlassian.net/l/cp/KKAXCs1K
I hope, it would be helpful for somebody.
Bhavna
March 13, 2025
It is very helpful. I was able to create a board with sample data. Thanks a lot.
Sid Suvarna
March 25, 2021
Thanks that was helpful
Jack Brickey
FWIW....for me the sample data just got in the way. but that is just me. :-)
What I would suggest is to create a demo/training project. IMO that is the best way to train new folks because it will continue to grow and have some real training data.
Kim Howitt February 15, 2018
I would like to know the answer to this as well.
