Sign up Log in
Creation of child issues with AI
Giampiero Celluprica
February 20, 2025 edited
I tried the "Suggest child issues" feature that is part of the Atlassian Intelligence.
Starting from a task reporting the minute of a meeting, including several action points, this feature suggests subtasks and automatically generate them filling their summary and description -> see screenshot below.
However, I have noticed that the "Due date" field of each subtask is always empty, even though they were cleary indicated for each action points reported in the original task.
Also, all the subtasks are not assigned to the users indicated for each action points.
Is there any way to get the Due date and Assignee fields automatically filled based on the info reported in the original task for each action point?
Thanks.
3 votes
Tomislav Tobijas _Koios_
February 23, 2025
Hi @Giampiero Celluprica ,
I believe that this AI feature only fills out Summary and Description fields (for now). As far as I know, there's no configuration option to change that.
You might want to take a look at open suggestions related to this feature. If there's no open one related to your requirement, you can probably reach out to Atlassian Support and discuss this with them. Their staff usually has another scan of open items/suggestions and they might open a new one for you.
Tobi
Payal _appbox_ai_
At appbox, we have developed a Marketplace application that enables you to create custom AI agents tailored to your needs. In the demo below, you'll see an example of an AI agent that automatically converts a ticket description into child issues. These agents are fully customizable, allowing you to define their behavior to suit your workflow.
In this example, we’ve configured the agent to extract the Due Date directly from the text in the Issue Description (meeting minutes).
We are actively working on expanding support for additional Jira fields, including Due Date and other custom fields, to enhance automation and flexibility.
Demo - https://youtu.be/-cBIRsbF36o
Team Appbox
Register Now
Upcoming Jira Events
