I am trying to create an automation rule in Jira that transitions Issues from one status to next based on an incoming webhook. The rule works fine when I make the call using postman But it does not work when invoked from a curl script on jenkins.
The response returned is 200 OK but when I check the audit trail on Jira for the automation rule I do not find any requests
JIRA_ISSUES='ECO-26074'
curl -v -X POST -H 'Content-type: application/json' --data "{\"issues\":[${JIRA_ISSUES}]}" "https://automation.codebarrel.io/pro/hooks/d817e8bff0ef3ea863a1ba92856ebeb54733b92f"
+ JIRA_ISSUES=ECO-26074
+ curl -v -X POST -H 'Content-type: application/json' --data '{"issues":[ECO-26074]}' https://automation.codebarrel.io/pro/hooks/d817e8bff0ef3ea863a1ba92856ebeb54733b92f
Note: Unnecessary use of -X or --request, POST is already inferred.
* Uses proxy env variable no_proxy == 'lvmita-back01n.adm.lvm.cvf'
* Uses proxy env variable https_proxy == 'http://proxy.srvc.cvf:3128'
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 10.175.20.51...
* TCP_NODELAY set
* Connected to proxy.srvc.cvf (10.175.20.51) port 3128 (#0)
* allocate connect buffer!
* Establish HTTP proxy tunnel to automation.codebarrel.io:443
> CONNECT automation.codebarrel.io:443 HTTP/1.1
> Host: automation.codebarrel.io:443
> User-Agent: curl/7.62.0
> Proxy-Connection: Keep-Alive
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0< HTTP/1.1 200 Connection established
* Proxy replied 200 to CONNECT request
* CONNECT phase completed!
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* CAfile: none
CApath: none
* loaded libnssckbi.so
* ALPN/NPN, server did not agree to a protocol
* SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
* Server certificate:
* subject: CN=*.codebarrel.io,OU=PositiveSSL Wildcard,OU=Domain Control Validated
* start date: May 01 00:00:00 2018 GMT
* expire date: Jun 27 23:59:59 2020 GMT
* common name: *.codebarrel.io
* issuer: CN=COMODO RSA Domain Validation Secure Server CA,O=COMODO CA Limited,L=Salford,ST=Greater Manchester,C=GB
> POST /pro/hooks/d817e8bff0ef3ea863a1ba92856ebeb54733b92f HTTP/1.1
> Accept: */*
> Content-Length: 22
} [22 bytes data]
* upload completely sent off: 22 out of 22 bytes
< HTTP/1.1 200 OK
< Content-Type: application/json
< Content-Length: 0
< Connection: keep-alive
< Date: Tue, 21 Apr 2020 16:20:17 GMT
< x-amzn-RequestId: 8b7164d9-31ed-4e66-9696-7e1d35e2effd
< x-amz-apigw-id: LWGCREruoAMFgNA=
< X-Amzn-Trace-Id: Root=1-5e9f1d41-32c78080eb575700023c7c80;Sampled=0
< X-Cache: Miss from cloudfront
< Via: 1.1 4c636d1acba4193747390c896124ffcc.cloudfront.net (CloudFront)
< X-Amz-Cf-Pop: CDG50-C1
< X-Amz-Cf-Id: 67d2EN4pvHch5GSzZS2yHWAiO6DDXECLfSLZ9J9QuAgM1N8iyHQkrg==
100 22 0 0 100 22 0 19 0:00:01 0:00:01 --:--:-- 19
* Connection #0 to host proxy.srvc.cvf left intact
Never mind. I found it. I had not quoted the issue ids within the array object
