I have created a custom field which is displayed on default issue screen. This is LOV with single selection. I have mapped this field with all the issues and with a particular project. Custom field is added on the Default screen which is called when user view, edit or look at issue screen. when i edit it, system still displays None as default value instead of default value I have set.
Please guide what step is missing. Thanks.
Hello
You probably have different contexts for that specific field. If so, you have to set the default value in the appropriate context.
You can check going to Custom Fields and selecting the Configure option for the field you are having trouble with.
all settings were correct as per your kind feedback but when i would see list of items and click edit button, system was showing None instead of default value I set. what I did to correct it is that i made it required and this value started appearing and i verified this by hitting the edit button and checking respective value.
Of course... there's that also... :-) you will always get None if the field is not required. Thank you!
I have default value as None but when ever I selected value and saved issues , then clicking edit it shows only default not selected value .
Do we have any solution for this ?
According to this documentation. You can specify by going to custom field > the click the cog on your desired field then configure there you can see the Default Value
Example screenshot:
I am also facing the same issue even though I have set Default Value for a Single Select Dropdown, Still it showing none.
I think, the default value will only be displayed when a fields ist displayed the first time. In your case in create step.
See documentation :"To edit the default value that a custom field contains when it is first displayed to a user:"
When you create, see if there is a default value?
Suggest to check the workflow of Create issue post function, whether some action empty the default value
This part is done. Still wondering what is missing =)
I made it required and by default it started showing by the crazy default value =) . Thanks all
Whether to set default values for it in Configure Custom Field?
