Custom REST API problem with @Inject @Named, not showing my apis at all
jira jira May 9, 2020
I am developing rest plugin for jira atlassian and I have this kind of problem. every time I want that my apis are showing up I need to add empty constructor to my new api in this format
import javax.ws.rs.Path;
import javax.ws.rs.Produces;
import javax.ws.rs.core.MediaType;
import javax.ws.rs.core.Response;
@Path("/import-issues")
public class ImportIssuesRestResource {
    private ImportIssuesAction importIssuesAction;
    public ImportIssuesRestResource() {
    public ImportIssuesRestResource(final ImportIssuesAction importIssuesAction) {
        this.importIssuesAction = importIssuesAction;
    @GET
    @Path("issueNumber")
    @Produces(MediaType.APPLICATION_JSON)
    public Response getFields() {
        return Response.ok().entity(importIssuesAction.getIssueNumber()).build();
However what I want is something like this
@Scanned
public class ImportIssuesRestResource{
    @Inject
    @GET
with injected constructor and @Scanned. I get this error when I am using the second version of code with @Named in ImportIssuesAction. I have tried also @Scanned.
 Error creating bean with name 'rest.ImportIssuesRestResource': Unsatisfied dependency expressed through constructor argument with index 0 of type [action.ImportIssuesAction] found for dependency: expected at least 1 bean which qualifies as autowire candidate for this dependency. Dependency annotations: {}
  The others custom implemented working api have similar injected constructor and using annotations @Scanned or @Named. I need my api real-time getting information from class. However currently I am getting NullPointerException from empty constructor in rest of my public getter getIssueNumber. When I am using  @Named @Inject combination the all of my custom apis are hidden.  I have tried also
<component-import key="importIssuesAction" interface="sk.eea.jira.telecom.extension.action."/>
in atlassian-plugin.xml.  In atlassian-plugin I have also
<rest name="CSMT Rest Resource" key="csmt-rest-resource" path="/csmt" version="1.0">
<description>CSMT Rest Resources</description>
</rest>
Can somebody help with implementing custom REST API?
Mohamed Benziane
Did you look a the community developer, i think you will find more answer. You can also post your question there.
https://community.developer.atlassian.com/
Hi thanks for answer, I will try luck on developer community too.
