Custom Subtasks does not work
Jan Sękara August 11, 2016
I've created custom subtasks and when I try to add them to an issue - the do not show.
Just the message that issue that i try to attach them to was updated.
Any idea what am i doing wrong?
Nic Brough -Adaptavist-
August 11, 2016
How are you adding them?  If it's via a popup, you might need to refresh the main issue for them to appear.
Also, what do you mean by "custom subtask"?  Is it just the standard "I've created a new type"?
I have created a new type of subtask,and added it to issuetype schemes
You can see this on video:
http://youtube.com/watch?v=25BKlO2yArY
August 11, 2016
After adding the task, what happens if you refresh the parent issue view?
Nothing happens, stays the same.
August 11, 2016
Ok, so no sub-task section appears at all on the parent issue?  Can you check that the sub-task is actually created?
