Custom Swimlanes based on Group
Felix Sargent
Hi!
Our team has several specialists on it. Some are in Ops, other in QA, others in Development etc.
How can we separate out their work into different swimlanes? Currently swimlanes are restricted to be useful for being expedited or not. Any way we can make swimlanes more flexible?
boardtc
December 4, 2012
Swim lanes just work off JQL.
Do you use the component field to categorise your issues as OPs/QA/Development. If so, you can add a swim lane per component (with the jql checking for the component value) if you want and name it appropriately.
Similarly you could use labels rather than compoent.
Felix Sargent
This is great. We assigned swim lanes based on Epic title. Thanks!
Tibor Szentmarjay
December 8, 2015
Any idea how to group by Columns automatically and not naming each one by one?
erento GmbH February 12, 2013
Tnx – but in addition to that, another problem arise …
I can now group UserStories with Swimlanes based on Epics like that, but if a UserStories have sub-tasks, the subtasks are not properly grouped to UserStories.
I tried following JQL – and it works
"Epic Link" = "NHATA-9" or (type = "Story / Task" AND (parent = "NHATA-2" or parent ="NHATA-14"))
Where 9 is an Epic, and 2 and 14 are UserStories. But this means that for every sprint I have to write/connect those UserStories to the Epics manually.
Now I read that there are some plugins for that but we are using the onDemand version so I can’t go for that.
Do you know a way to solve this dynamically in a onDemand version?
Tia Nermin
Felix Sargent
hi Felix, can u pls explain how to do that - i tried
"Epic Link" = "EpicName2" OR "Epic Name" = "EpicName2" but it does not work?
tia Nermin
Learn more
