Sign up Log in
Custom Ticket Fields
Carly Mojica August 16, 2024
On my epics, I currently have the requirements for a feature listed in the description, like so:
I decided that it would be nice to use the description field for a high-level overview and insert new custom fields for Requirements. I added a new custom field with the paragraph option (supports rich text). However, while it lets me type freely in this box, there is no way to create a numbered list that will create a sub-list item when I indent. Is it possible to add a custom field with the option to create a numbered list, like the description field?
3 votes
Mikael Sandberg
August 16, 2024
In order to enable the rich text editor for your custom field you have to go and change the renderer used. Go to Project settings > Fields and click on the pencil to edit the field configuration. Next locate the field and click Renderers and select Wiki Style Renderer.
Excellent! You just made my day. Thank you!
Like # people like this
