Whenever an issue is created or edited, JIRA pops up a message in the top right corner, like below:
image2017-1-3 23:30:24.png
I want to either display my own message in addition to that or modify the existing one based on the value of a scripted field. My scripted field is an AUI message (following the instructions here https://scriptrunner.adaptavist.com/4.3.0/jira/recipes/scriptfields/informationMessage.html), and it shows up perfectly on the issue. I just need the same message in a popup alert as well, on issue create and issue update.
I tried using UserMessageUtil in a scripted listener, but that does not work. It seems like UserMessageUtil is only meant for validators.
What is the recommended approach for this?
So after some testing, I added a scripted listener for Issue Created and Issue Updated, as follows:
import com.onresolve.scriptrunner.runner.util.UserMessageUtil UserMessageUtil.success("This is a test message.")
Originally, I thought it wasn't working at all, but now I see that it works but at the wrong time. For instance, if I hit update on the issue, nothing shows up, but then if I open another issue in the issue navigator, the test message shows up. Same with issue create–if I create an issue, nothing shows up, but if I refresh the page or navigate to another issue, the message shows.
It's like the timing of the event is off. Does anyone else experience this?
@Irtiza Rizvi Hi,
Did you end up solving the issue with the wrong message timing? I encountered the same problem, used a script in post function, called the message Util and only when I use issue view it works well, when I use other window, i.e right click on issue options, it is not triggering.
I wondered if you found a solution to this?
tx,
Esty
@Irtiza Rizvi Hi, could you provide a bit more details on how you use the AUI message (https://scriptrunner.adaptavist.com/4.3.0/jira/recipes/scriptfields/informationMessage.html)) ?
Is it possible to use it with behaviours ? I would like the user to get a popup after evaluating a field on the issue.
Thanks !
Antoine
Another observation: if the scripted listener is assigned to "All Projects" instead of a specific project, then the timing is off only SOMETIMES.
Overall, it's behaving very oddly.
the code available on the repo below is also working with this dialog box, it might be of some help :
But beware that it's not the same box that is provided by the SR info message (in the issue view, always visible on the issue) and this dialog box (in javascript, reacting on some event).
Thanks for the response. How do I setup that JS code to execute on issue create / update?
