Custom calculated field defintion and configuration
Geert Truyen
What is the easiest way to define a calculated custom field for an issue for this example:
Custom field A: entered value
Custom field B: entered value
Custom field C: A X B
Any guidance that can quickly show me the config steps would be much appreciated.
Doc is not very clear.
Thank you!
Igor Loskutov
July 27, 2012
here is link : https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Igor Loskutov
July 27, 2012
Try this one : https://studio.plugins.atlassian.com/wiki/display/GRV/Scripted+Fields
Geert Truyen
Thank you Igor,
Will this work for on demand JIRA as well?
Geert
Igor Loskutov
July 27, 2012
Here is link : https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner
Igor Loskutov
July 27, 2012
Most of Atlassian Marketplace plugins work with onDemand but I cant' give you warrancy cause use only box version myself. Try it and write about it here, I'm curious too.
Nic Brough -Adaptavist-
July 28, 2012
I'm afraid Igor is wrong about plugins and OnDemand. You can NOT install plugins in OnDemand, other than the ones Atlassian have accepted (you can disable the ones they've accepted, but not add your own)
See https://confluence.atlassian.com/display/AOD/Atlassian+OnDemand+Plugin+Policy They are looking at extending the plugins they allow, and some way of ring-fencing installs to give you more freedom to install plugins, but currently, you can't install things that aren't on the list, and the script-runner is not.
Igor Loskutov
July 28, 2012
That's right, my fault
Register now
