Custom event not firing
Grant Donovan
I have looked in the forum but still having issues
I want to create a custom event (send and email) when a ticket moves throigh a transition
This is what I have done
  • Created the custom event through system
  • Added the event to the notification scheme and attached that to send to groups and single users
  • Changed the workflow (generic event) to point to my custom event
  • I am using a test user who should receive the email
I never get the email
What could be causing the issue and how can I troubleshot more
Grant
Grant Donovan
I contacted support.  Although I was testing with other accounts, the ones I chose were service accounts , that is is why it didn't work
Grant
Nic Brough -Adaptavist-
March 19, 2019
The one that I trip over regularly - is your test account who should get the email the same account you are using to go through the workflow?  If so, check their profile - you need to make sure the "email me on my own changes" flag is set to "on", otherwise Jira won't email them.
Kevin Suter
Thanks Nic. Solved my problem.
Taranjeet Singh
@Grant Donovan First check that you have correctly followed the steps for setting up Custom events and configuring notifications for it, from the below document: https://confluence.atlassian.com/adminjiracloud/custom-events-868983028.html
If everything seems fine there, then since this is JIRA cloud and you won't have access to application logs, so I would suggest to contact Atlassian Support with your issue: https://support.atlassian.com/contact/#/
