Custom field not appearing in ANY field configuration
Jamie Williams September 10, 2018
When I create a new custom field, they then do not appear in ANY field configuration, not even the system Default configuration.
I have tried entering Safe Mode and the issue persists.
I have tried re-creating the field configuration and the custom field but still no luck.
Jamie
Nivash Mathuramuthu
June 6, 2023
Danyal Iqbal, Did you find the reason? I am facing the same.
Jamie Williams October 1, 2018
Update: This was solved by removing 2 custom fields that had script data hidden in their descriptions.
Mohamed Benziane
Hi Jamie,
Can you try this:
1 - As an admin go to the administration panel (click on the cog icon and then issue)
2- click on Custom fields> hint Add custom field button
3- Create your field
4- Add it to the Default Screen
Go to field configuration and look for the customfield in  Default Field Configuration
Do you find it ?
Hope this helps
Sorry for my english
Regards
Jamie Williams September 12, 2018
Nope. That did not work.
Danyal Iqbal
September 10, 2018
You have to add the new custom field to a screen first .
Thanks for the answer, but that doesn't seem the case. I've added several to 1+ screens after I create the custom field and still doesn't appear in field configuration.
Appears on the screens fine though.. just cannot make "required" and other settings you set in field configuration
Let's build A Rovo Agent 🤖
Save your spot
