×I need to group a report by a custom field, but I do not see it in the drop-down list, but there are other custom fields, the field is called Epic/Theme, can it be its name? How can I add this field?
Мне нужно сгруппировать отчет по пользовательскому полю, но я не вижу его в выпадающем списке, но другие пользовательские поля имеются, поле называется Epic/Theme, может дело в его назывании ? Как я могу добавить это поле ?
looking at the report symbol I assume it is based off the App "Log Work Utilities".
Seeing from Marketplace it has currently 9 installations with customers it might be that you receive the information you are looking for here in Community - but perhaps this won't be the case.
Support seems being limited as this is a free App, however you could try to contact the vendor with this specific question.
https://marketplace.atlassian.com/apps/1214103/log-work-utilities?hosting=server&tab=support
It is also perfectly fine to wait for some other users which are familiar with this App to let them answer here.
Daniel
Which report is it? Epic/Theme is not usually a groupable "field", as it's a pointer to something else rather than a value, but how it is used is up to the actual report, not the field.
This is a Team Reports report from the dashboard in developer projects
