Hi all,
I am trying to add custom filed on custom issue type only. However, when I add that filed it shows on another issue types as well. This is related to one project only.
Aleksandar
Hello Aleksandar,
I believe your issue with a custom field being visible on unintended issue types is related to the field's configuration settings. To resolve this, please try the following steps:
This should restrict the visibility of your custom field to only the specified custom issue type within your project.
If you need further assistance, please provide more details about your Jira configuration and the specific custom field type you're using.
Don't hesitate to reach out if you need any additional help!
Best regards,
Eric
First, you should be creating the create, edit/view screens for your new issue type with your custom field.
Second, you need to apply these screens to the screen schemes and finally you need to create an issue type screen scheme, where you will define the scheme for your newly created issue type.
Also, you need to apply these changes to your project directly by adding this newly created issue type to your project.
You can do it using context field
You can also use field configuration and field configuration scheme:
Manage issue field configurations | Atlassian Support
Configure a field configuration scheme | Atlassian Support
