Dear,
I would need to make a customized automatic report for a test cycle to show the number of test cases, how many failed, blocked, passed, remaining .. ( Test Execution results).
But, I would need to get a list for the failed and blocked test cases with the next columns:
Test case ID/ Test case description /Tester/ Reason/ Comments
Can I custom reports?
Can I build a dashboard with several reports?
I must generate hundreds of them and I would be really useful to automate a dashboard.
Thank you
Please note that Zephy is a third party app and if you want to custom report in zephy- dashboard, you need to reach out to the Zephy support team for assistance using the below link - https://support.smartbear.com/
You might get that level of detail from the Test Execution (detailed) report, but either way, it is not possible to customise the columns of any Zephyr report.
