Custom scriptrunner validator with select field and number
valeria cruz
Hello guys!
I"m trying to do a custom script validation using script runner.
My script needs to validate two types of scenarios.
1 - custom field ST( type select list) with values A or B and custom field CP (type number field) with no value (null) needs to return an error because the CP field can't be empty if ST has value A or B.
2- The second scenario is similar, but the field CP can be empty if the ST field has C or D values.
Follow my script
import com.opensymphony.workflow.InvalidInputException
import com.atlassian.jira.issue.customfields.option.Option
import com.onresolve.scriptrunner.runner.customisers.PluginModule
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
import com.atlassian.jira.issue.managers.DefaultIssueManager
def issueManager = ComponentAccessor.getIssueManager()
def userManager = ComponentAccessor.getUserManager()
def ST = customFieldManager.getCustomFieldObjectsByName("Story Type")
def CP = customFieldManager.getCustomFieldObjectsByName("Complexity Points")
if (ST == 'C' || ST == 'D' && CP == "null") {
return true
log.info("ST C AND D")
else {
(ST == 'A' || ST == 'B' && CP == "null")
return false
throw new InvalidInputException ("CP can be empty")
log.info("ST A AND B")
It seems that the validation script isn't running (but is running), and I didn't receive the log info return.
In attachments are some prints from my WF.
Can you kelp me?
Prince Nyeche
September 12, 2021
Why is null a string within your code block? It seems to me the script ran and found that the condition set didn't match, so it skipped the block and exited.
rahuldanwade
September 11, 2021
Hello Valeria,
ST & CP are references to the Custom field objects.
You need to use the below methods to fetch the cf values for the issue.
ST.getValue(issue)
CP.getValue(issue)
You can use a simple one-line validator from Scriptrunner rather than writing the script.
May explore cfValues built-in wrapper/map-like structure to fetch CF values rather than importing many classes and writing script for simple validations.
Rahul
Nic Brough -Adaptavist-
September 10, 2021
The green "script has run ok" flag is only telling us that the script ran and "worked" - for a validator, that means it returned something to Jira that was a "yes or no on the validation question".  It will only go red/fail when the script fails or crashes and returns "it's all gone horribly wrong"
For the rest of the question about comparing strings to option objects, I wrote something on this a few hours ago, over at https://community.atlassian.com/t5/Jira-questions/Custom-Script-Post-Function-ScriptRunner/qaq-p/1801628
Pramodh M
SERVER
VERSION
8.13.3
