Hi All,
Just was wondering how to search and revert (restore) an old value for an custom field in JIRA.
Ex: let's say I have an instance of 200,000 issues spread across 200 projects.
then I have modified 25,000 issues from value A to Value B Instead of Empty.
How do i get the original value back apart from reverting the instance since I have aleast 100 to 200 updates in an hour.
Thanks in advance,
Rathna
WAS only works for a small handful of system fields at the moment.
I can't think of a simple way for you to revert, beyond sticking a backup into a development system and searching that for any changes you might have made in error.
