Customize fields appearing on resolution screen based on labels
GlenellRosburg
How can I make 2 additional fields appear on the resolution screen and make the fields required based on specific text entered in my Labels field?
I'm on Jira Cloud a
I tried to make fields appear on the resolution screen based on specific conditions in the Workflows Transition settings. Is this where I would set this?
I tried to create an automation.  I can't find an action that allows me to modify a screen field based on a transition to done.
Hmmmm....
Samuel Gatica _ServiceRocket_
August 2, 2024 edited
Hi @GlenellRosburg
Regrettably, this cannot be accomplished using the native tools available in Jira. https://jira.atlassian.com/browse/JRACLOUD-71000
This can only be accomplished with a third-party add-on like Behaviours - ScriptRunner for Jira Cloud
Check vendor doc at https://docs.adaptavist.com/sr4jc/latest/features/behaviours
Best regards
Sam
Read the story
