Customize the "Create issue from" Slack
Gilad Waldman
Hello, This is probably a common issue but i couldn't find a proper answer that would help me.
I wish to customize the create issue screen while creating an issue from Slack. This should be working for two projects - Regular Software project and a Discovery project (JPD).
For the software project, i was trying to add a new screen that is set for create action, and choose there only the fields i want to see, but for some reason i keep seeing many other fields.
For the Discovery project, there is no option to customize screens so im not sure how could i do that? Is there a solution coming up or should i look for an app that will help out with this?
Thanks.
Alper Saglam _actioner_
April 30, 2024 edited
I don't know if you are looking for this but the forms that are shown to the user are easily changeable when you use Actioner's Jira Software app.
Here is a video showing that when you remove a field from the configuration for a specific project and a specific issue type, it is gone from the Slack `create an issue form` also.
The good thing is it can be done in a few minutes by changing the app to your custom needs.
Best,
Alper
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
