Customizing Tempo / JIRA to allow zero hour work logs.
Andrew Taverna
July 28, 2016
I am trying to find a way to allow my staff to log zero hours but add billed hours. Currently, I am unsure how to do this. I believe I should be able to remove the field validation because I am on JIRA Server 7.1 and Tempo 8.
Does anyone have any experience doing this?
Andrew
Hlynur Johnsen
August 9, 2016
Hi Andrew,
Worked hours must always be larger than 0 when logging work via Tempo Timesheets.  This is actually also the case when using JIRA Log Work.  Could you perhaps describe in a bit more detail what you are trying to achieve so that I can recommend alternative solutions?  I'm also interested to see if this is something we should consider for improvements of the product.
Hlynur Johnsen
Product Manager - Tempo Timesheets
Andrew Taverna
August 9, 2016
Hi Hlynur,
What we are trying to do is make it so that people can have billed hours go to our customer but not have to actually do any work on the issue. We have issues we use for things such as updates which happen automatically, but we will the customer for them.
Do you have any proposed solution for that problem? I don't want people spending time on them, but I want them getting billed out at the end of a month.
Andrew
Hlynur Johnsen
August 9, 2016
Since there is no actual work taking place, I would suggest using something else than Log Work for this.  Timesheets 8 includes the option to record expenses (Issue view->More->Add Expense).  This allows you to log categorized expenses.  The amount logged on expenses is summed up in the Time and Expenses report, also added in Timesheets 8.
For more information please see:  https://tempoplugin.jira.com/wiki/display/TEMPO080/Adding+expenses+to+JIRA+issues
Hope this helps,
Hlynur
Susanne Harelius [Riada]
August 31, 2017
Interesting. We have a scenarion where we log traveltime - outside office hours. This will only give half pay for employees and some customers pay for travel time so we still need to track the time but the hours should not count in the weekly hours for the employee.
Help us plant more trees
