Custon JQL Function, User in Group from custom field
David Harkins
May 4, 2023
Trying to get the following custom JQL Function working in data center.
To compare a custom field and check if its group value is in the list of groups that the current user is a member of.
package com.onresolve.jira.groovy.jql
import com.atlassian.jira.JiraDataType
import com.atlassian.jira.JiraDataTypes
import com.atlassian.jira.jql.operand.QueryLiteral
import com.atlassian.jira.jql.query.QueryCreationContext
import com.atlassian.jira.permission.ProjectPermissions
import com.atlassian.jira.project.version.VersionManager
import com.atlassian.query.clause.TerminalClause
import com.atlassian.query.operand.FunctionOperand
class AssignedToMyGroups extends AbstractScriptedJqlFunction implements JqlFunction {
    def versionManager = ComponentAccessor.getComponent(VersionManager)
    def permissionManager = ComponentAccessor.getPermissionManager()
    @Override
    String getDescription() {
        "Issues where Group field is one of My Groups"
    @Override
    List<Map> getArguments() {
        Collections.EMPTY_LIST // <1>
    @Override
    String getFunctionName() {
        "AssignedToMyGroups"
    @Override
    JiraDataType getDataType() {
        JiraDataTypes.VERSION // <2>
    def groupManager = ComponentAccessor.groupManager
    def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
    final username = loggedInUser.username
    @Override
    List<QueryLiteral> getValues(
        groupManager.getGroupNamesForUser(username)
David Harkins
May 16, 2023
Made some progress, Now showing up in the Scriptrunner JQL Functions, but not having the desired effect.
    @Override
        "Issues where Group Custom Field is one of the Current Users Group"
    @Override
    @Override
    @Override
        ArrayList // <2>
    @Override
        QueryCreationContext queryCreationContext, FunctionOperand operand, TerminalClause terminalClause
            def username = loggedInUser.username
            def groups = groupManager.getGroupNamesForUser(username) as ArrayList
            return groups
The purpose is to return all the groups that the current user is a member of so that a Single Group Custom field can be checked to confirm if it is in the list of groups.
David Harkins
June 7, 2023
So, after some digging around and research, I have a working version now :-)
I located a comment on a similar topic by @JamieA, which let me to GitHub and the following JQL Function which gave me my missing pieces. CurrentTeams.groovy · GitHub
My final code is:
class groupsOfCurrentUser extends AbstractScriptedJqlFunction implements JqlFunction {
@Override
"Get Current Users Groups"
@Override
List<String> getGroups() {
groups
@Override
JiraDataTypes.TEXT
@Override
"groupsOfCurrentUser"
@Override
List<QueryLiteral> getValues(QueryCreationContext queryCreationContext, FunctionOperand operand, TerminalClause terminalClause
getGroups().collect{
new QueryLiteral(operand, it)
Hi @David Harkins
Could you provide more information on what exactly you are trying to do?
What type of custom field are you using? Is it a group picker or a user picker? I am requesting this information to try to provide a sample code.
I am looking forward to your feedback.
Thank you and Kind regards,
Ram
David Harkins
May 10, 2023
Hi @Ram Kumar Aravindakshan _Adaptavist_
Thank you for taking the time to reply :-)
The Custom Field that will be used is a Group Picker (Single Group)
This will then allow us to better associated / assign issue to a group of agents that have the respective skills based on group membership.
Many Thanks
David
Hi @David Harkins
Thank you for providing the information.
I have a couple of questions to ask, i.e. what approach do you want to use to assign the issue, i.e. Post-Function, Listener or Behaviour?
Secondly, since you are taking this by groups, the Assignee field can only add one person at a time. What other conditions do you intend to use to filter out the most appropriate person from the group to assign the issue to?
Ram
David Harkins
May 10, 2023
The value of the 'Assignee Group' custom field will be populated by listeners and a combination of defined class methods.
What we are trying to do here is create a filter to show all issues where the current user is a member of the group name that is in the 'Assignee Group'
Agents can then see all issues that they have the skills to progress, they can then assign the issues to themselves.  But still remain with the group to handle agent working hours and vacations for 24/7 coverage.
May 11, 2023 edited
Hi @David Harkins
Going through your latest comment, this is not doable.
You can restrict the Issue Type by Role or Group visibility during the Create / Edit / Transition screen using ScriptRunner's Behaviour
However, once the issue is created, all users can view it on the view screen.
A similar question was asked in this Community Post.
Ram
David Harkins
May 12, 2023
Maybe I've not explained myself very well, or over explained.
One Custom Field on the issue.  How it gets populated is already handled.
The reason for this custom scriptrunner JQL is to return issues where the current user is a member of the single group that is in the custom field.
Yes, all agents can view all issues in the project, this JQL will allows queues and dashboards to be created that are specific for the currents users skill set.
If the above code returns all the groups that the current user is a member of,
then if the group in the custom field is in the returned list, the issue will be returned in the JQL output.
