Dashboard Template
Bob Bandsuh
November 19, 2024 edited
I am a program manager and want to create a dashboard template which can be used by multiple teams on the project.  Want to show:
  • Cumulative Flow
  • Status of Epics based on Fix Version
  • Recently completed Stories / Sprint Result
  • Open Bugs
Ideally it would be great to use on Dashboard and filter by Team
Marlene Kegel - codefortynine
Welcome to the community, @Bob Bandsuh.
I am Marlene, product manager of Quick Filters for Jira Dashboards.
Many of our customers use our app to build one dashboard that can be used by several users.
As you've mentioned, we offer a Quick Controller gadget that enables you, to filter all other gadgets on your dashboards dynamically. You can test this functionality without installation on our demo dashboards.
Here you can find all Quick Gadgets that are available at the moment.
Danut M _StonikByte_
Hi @Bob Bandsuh,
Jira does not have a native Cumulative Flow Diagram gadget.
A solution would be to search on Atlassian Marketplace for an app that provides such gadget.
If you consider the idea of using a plugin, our Great Gadgets app offers all you need for creating a dashboard like the one you mentioned.
1. Cumulative Flow Diagram Chart gadget (by status, status category, issue type, etc)
2. Pivot Table & Pivot Chart gadget able to display the status of epics by Fix Version
3. To list the recently completed stories you could use Jira's Filter Results gadget. But you can also used the Sprint Burndown Burnup Chart gadget or Team Velocity gadget offered by our app. They can also display a Data tab with all the issues.
4. If you just want to display a list of open bugs, you can use Jira's Filter Results gadget. If you want to display this as a number of chart, you can use Advanced issue Filter Formula gadget, or Cumulative Flow Diagram Chart gadget (configure by issue type and to display only bugs). The app offers other gadgets for tracking this.
See also these articles:
if you need any help with the configuration of our gadgets, feel free to contact us at support@stonikbyte.com.
Danut.
