Dashboard with one gadget providing totals of a filter
Mike Marien May 15, 2024
Hi All,
  I have been searching with no luck so I figured I'd ask.  I have filters created for counting specific tickets based on the critera of the filter.
  An example would be to give me all tickets in one Project.  And then a second to give me tickets in that Project that exclude users or a 3rd to give me tickets including specific users.
  Again, I created all the filters, but I cannot find a gadget that will allow me to just throw counts.  I don't need the list of the tickets, just the total counts of a specific filter.
  I've looked at a few addons but I cannot find something that is this simple.
  Just curious for thoughts/help. :)
Danut M _StonikByte_
May 15, 2024 edited
Hi @Mike Marien,
Have a look over our Great Gadgets app. It offers some gadgets that will full-fill your request. They are easy to use.
Advanced Issue Filter Formula Gadget - lets you display the count from up to 6 filters, but also to sum-up fields, calculate average, percentages, ratios or any math formula. The result is displayed as number.
Issue Filter Formula gadget -  let's you display the count from one filter, but also to sum-up a field or calculate average. Result is displayed as a number or as gauge chart.
Very useful for you could be also the Pivot Table & Pivot Chart gadget offered by the same app.
You could start with a 1-month of free trial. If you have any questions, feel free to contact us at support@stonikbyte.com.
Hope this helps.
Danut.
Frank Leclerc [Decadis AG]
Hi @Mike Marien ,
have you already looked at the standard gadget "Filter Counts" from Atlassian?
When you select the filter and a measure (e.g. Total), it seems to me that exactly what you want is displayed.
Best regards
Frank
May 15, 2024
Hi @Frank Leclerc [Decadis AG]
I believe that gadget is for JSM customers only.  Have you see it installed without JSM?  Thanks!
I like that gadget from what @Frank Leclerc [Decadis AG] mentioned but we don't have JSM.
It seems weird tho that such a simple gadget would only be applicable to JSM and not conventional Jira.
Jamie July 22, 2024
FYI Filter counts widget for some reason is no longer supported and was recently removed. Disappointing.
July 23, 2024
Hi @Jamie -- Welcome to the Atlassian Community!
Just to confirm...was that gadget removed from the ones provided with Jira Service Management (JSM) or did your team stop using JSM...and so the gadget is now removed?
Jamie August 18, 2024
We didn't seem to stop using JSM when it disappeared, but then later it magically returned and I could add it back to my dashboards. But yeah maybe our Jira Admins where stuffing around with things and temporary change something.
Like • Bill Sheboy likes this
Chris Rainey
Hey Mike,
I'm not sure this will give you exactly what you're looking for, but try a gadget called "Issue Statistics". The results are displayed like this: statistics1.PNG
It may not be super ideal since you'd need to configure it for each filter, but could be an option.
There is another dashboard gadget called "Filter counts", but you'd need to have access to Jira Service Management for this to be available. This is how that gadget would look:
Mike Marien May 16, 2024
So I did try down this route with the Issue Statistics gadget.  As I wanted to have 3 F1ilters for one year on a page, I ran into the Dashboard gadget limit of 20.
For the time being, I have created three pages with the 12 gadgets each.
That being said, I may try out what @Danut M _StonikByte_ suggested.  I'll test that out, if it does what I need.  I can subscribe and then ask for forgiveness from Finance instead of starting with permission. ;)
Like • Chris Rainey likes this
