Database connection
HaRsHaS_ V October 12, 2020
I am trying to connect my Jira sandbox account to my sql.. its giving an error that the database is not empty. I have a fresh new database and trying tot connect. i don't understand why this error is throwing up
ERROR MESSAGE
"You have specified a database that is not empty, please specify an empty database. If you want to upgrade an existing installation, please follow these instructions instead" -
Martin Bayer _MoroSystems_ s_r_o__
hi @HaRsHaS_ V it happened to me when there was some table already created in my database. Is it really empty or some "default" table was created in the database you want to use?
Can you give us more detailed information? What type of database? What Jira version etc.?
@Martin Bayer _MoroSystems_ s_r_o__
mysql> show databases;
| Database |
| information_schema |
| jira |
| mysql |
| performance_schema |
| sys |
5 rows in set (0.00 sec)
mysql> CREATE DATABASE jiradb;
Query OK, 1 row affected (0.00 sec)
mysql> show tables;
ERROR 1046 (3D000): No database selected
mysql> use jiradb;
Database changed
mysql> show tables;
Empty set (0.00 sec)
jira version: 7.13.9
And for jiradb it still fails? Can you check Jira log files? ({JIRA_HOME}/logs/atlassian-jira.log)?
You should know only some versions of MySQL are supported by Jira 7.13 (https://confluence.atlassian.com/adminjiraserver0713/supported-platforms-964983071.html)
PLEASE FIND THE LOG DETAILS
2020-10-13 08:03:24,323 http-nio-8080-exec-14 ERROR anonymous 483x191x1 v8buqr 0:0:0:0:0:0:0:1 /secure/SetupDatabase.jspa [c.a.config.bootstrap.DefaultAtlassianBootstrapManager] Could not successfully test your database:
java.sql.SQLSyntaxErrorException: Unknown database 'jiradb'
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:120)
at com.mysql.cj.jdbc.exceptions.SQLError.createSQLException(SQLError.java:97)
at com.mysql.cj.jdbc.exceptions.SQLExceptionsMapping.translateException(SQLExceptionsMapping.java:122)
at com.mysql.cj.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:836)
at com.mysql.cj.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:456)
at com.mysql.cj.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:246)
at com.mysql.cj.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:199)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:247)
at com.atlassian.config.bootstrap.DefaultAtlassianBootstrapManager.getTestDatabaseConnection(DefaultAtlassianBootstrapManager.java:347)
at com.atlassian.jira.config.database.JdbcDatasource.getConnection(JdbcDatasource.java:211)
at com.atlassian.jira.config.database.DatabaseConfig.testConnection(DatabaseConfig.java:88)
at com.atlassian.jira.web.action.setup.SetupDatabase.testConnection(SetupDatabase.java:225)
at com.atlassian.jira.web.action.setup.SetupDatabase.doValidation(SetupDatabase.java:189)
... 2 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
... 45 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 31 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 24 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 25 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
@HaRsHaS_ V hm, this is weird, I guess you are using correct user - user which has permission to access database. And version of MySQL is valid?
@Adam Rypel _MoroSystems_ do you have any idea why it's not working?
Harsha Vardhan Doddi October 13, 2020
I got the issue resolved, Looks like I was using a java connector of higher version, i used a lower version and it worked.
thank you so much!
@Harsha Vardhan Doddi ok cool...so the supported platforms document should be always on mind 🙂
