Database picker fieldt the given input text parse in another field
A May 23, 2024
In Jira, the database picker can use the given input text in another field.I want this value to appear automatically in customFieldId=10200 field
Sebastian Krzewiński
Hi @Detsha
What is customfieldid=10200?
Did you try to do that via automation?
Seba
A May 24, 2024 edited
Hİ. @Sebastian Krzewiński  Thanks for the feedback.
Let me explain that I have 2 fields. Ibs_kod and customer_name. Ibs_kod is a database picker field. Ibs_kod returns the customer's name to me when the customer writes the code. I want it to write the returned name in  customer_name field automatically. customfieldid=10200 is the id of the customer_name field.
Automation works after issue creation. I want it to still be on the create screen
with jira out-of-the-box it is not possible. You can consider to use script runner but I'm not sure if behaviours will solve that.
IMO only solution is to use automation.
Seba
A May 27, 2024 edited
OK. But how can I do this with automation? I want the other cell(customer_name) to be automatically filled according to the information in the database when I enter the customer code on the create screen.
What you need to do is to create rule that will be triggered after issue created action. Then you need to set condition/conditions for each case (e.g. if field is ABC then fill customer_name with XYZ)
Seba
FREE
Register now
