Default available issue types missing
James Burnett
September 23, 2015
The default issue type scheme I am using only has task and sub-task. I am expecting to see sub task, bug, improvement, new feature and task.
Where can I make these other issue types available?
Mauro Badii
September 28, 2015
Hi James,
JIRA doesn't have default issue types any more.
Issue types are now created when Projects are created.
Bug issue type is created when a Software project is created and that project type is available with JIRA Agile.
You can create your own issue types and associate them on a Workflow Scheme for having bugs, features and other issue types associated to your projects.
We still need to get some documentation updated regarding this.
Here is more on Associating Issue Types with Projects
Cheers
Jon Wong
October 4, 2015
I was confused about this when I signed up for a new JIRA account. I was already very familiar with JIRA cloud before. Thanks Mauro.
Darren Broadhead
January 23, 2017
Thank you Mauro.  I was starting to panic that I had to wipe the whole cloud instance and start again.  I am going to leave it with missing stories if it is not going to be used.
Pilar
September 23, 2015
You can create a new issue type scheme and add those issue types in that scheme.
Then apply this issue type scheme for your project, then all those issue typeswill be availablefor your project
https://confluence.atlassian.com/jira/associating-issue-types-with-projects-185729585.html
Pilar
