Default description in Forms
Maruf Mamurov
Hi all!
Is there any way to add a default description in Forms?
Otherwise our customers should copy table for filling and add it to description manually.
Karyna Tyrnavska _SaaSJet
July 19, 2022 edited
Hi, @Maruf Mamurov !
If I correctly understand you, try to create a form template with the text field as you need.
And change the Label to your custom. So, your customers shouldn`t copy the table for filling and add it to the description manually.
Try out Smart Jira Forms with full functionality for free.
