Default reporter
Olatunde Jimoh
March 22, 2024
Hello Community,
How do I set a default reporter for all the ticket created on a project?
3 votes
Mikael Sandberg
You cannot set a default reporter, it will aways be set to the person that clicked the create button by default. You can manually change that when creating the issue, or have an automation that changes it after the issue has been created.
Ste Wright
Hi @Olatunde Jimoh
You'll need to use Automation for this - for example:
  • Trigger: Issue created
  • Action: Edit issue
    • Field = Reporter
      • Value = <user here>
You could also add a Condition if needed - for example, if this is only relevant to a specific issue type.
Ste
