×Does anyone knows where to find config to set default users or groups, when I create the project?
It's in the project role settings - go to Admin -> System -> Project roles and you'll see a list of all the roles you have, along with links for "manage default members"
The default members are added to the roles in new projects when you create them, changing the members of these defaults will not affect existing projects.
I don't think so this functionality Jira haves by default.
I would like you to read this.
Default project roles
When you install Jira applications, the Administrators role is automatically created, along with project roles specific to each application. You can create, edit, and delete project roles according to your organization's requirements.
A system role is a specific type of default project role that's managed automatically by Jira (for example the atlassian-addons-project-access role). You can't edit or delete these roles, or manage their project role membership.
Viewing project roles
Choose > System.
Under SECURITY, select Project roles. The Project Role Browser displays, which contains a list of all the project roles in your Jira site.
To see where a project role is used, click the View Usage link. This displays a list of the project role's associated permission schemes, email notification schemes, issue security levels, and workflow conditions.
Click any of the View links in the Project Role Members Per Project column to see which users/groups are associated with a project role for a particular project.
I should be somewhere, becouse during create project process Jira add by default some old/unactive accounts. Unfortunatelly, from some time Jira instance change this config and remove jira-admin group so I must do some workaround do get an access to the project.
