I've found here a following suggestion for defining different resolutions per workflow.
But how or where can I find the Resolution id
Workflow properties jira.field.resolution.exclude and jira.field.resolution.include Details
: http://confluence.atlassian.com/display/JIRA/Workflow+Properties
Leo
Go to Admin -> Issues -> Resolutions and get the list. If you hover the cursor over any of the links for edit/delete an existing option, the url will have a parameter of id in it, which is the number you need there.
