I have a one-off use case where I have issues under a specific epic and want to remove attachments for all stories under that epic.
I do have script runner but have not found an example to accomplish this task.
Appreciate any help that can be provided.
I also recently found this video but did not have automation installed yet. We are in the process of testing 9.4 and the automation built into JIRA and this method did work.
I also worked with Scriptrunner on an older script that does work as well.
import com.atlassian.jira.bc.issue.search.SearchService // <-- add new import
import com.atlassian.jira.issue.MutableIssue; // <-- add new import
// more imports
def findIssues(String jqlQuery) {
def issueManager = ComponentAccessor.issueManager
def user = ComponentAccessor.jiraAuthenticationContext.getLoggedInUser()
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser) // <-- changed here
def searchService = ComponentAccessor.getComponent(SearchService) // <-- changed to Search Service
def query = jqlQueryParser.parseQuery(jqlQuery)
def search = searchService.search(user, query, PagerFilter.getUnlimitedFilter()) // <-- changed here
search.results.collect { issue ->
issueManager.getIssueObject(issue.id)
def attachmentManager = ComponentAccessor.getAttachmentManager()
def jqlQuery = "your-jql-query"
def issues = findIssues(jqlQuery)
issues.each{issue ->
def attachments = attachmentManager.getAttachments((MutableIssue) issue) // <-- typecast it to MutableIssue
attachments.each {attachment ->
attachmentManager.deleteAttachment(attachment)
