×Hello,
I would like to delete a filter from this page:
https://foo.atlassian.net/secure/ManageFilters.jspa
This filter contains a subscription that is owned by a user that is disabled. This subscription is setup to email a group.
Apparently, site admins (me and others at my company) are not able to remove this disabled user’s subscription.
As a workaround, I made a backup copy of the filter and now want to delete the original filter (thus removing the subscription).
When I go to delete the original filter, I get this:
I'm pretty sure this filter is not associated with a board.
Questions:
to the right under "Related Content" you will see a link to Remove-filters-subscription-of-a-non-existing-user. That will give you the answer which is basically - if you don't have access to the user you cannot. But consider reactivating the user and as an admin log in as that user and take care of business. then you can deactivate again.
Ah, that makes sense. I was considering that, but we were wanting to avoid re-activating the user. I suppose re-activating the user for a few minutes wouldn’t be too risky. We’ll give that a shot and report back our findings. Thanks!
I'm having the same issue as well. In my case the original creator of the filter is no longer at the company.
Register Now
