I have an issue highlighted. I am clicking on the 3 dots in the upper right. I see 5 options but none of them are 'delete'. I have admin rights. Is there another setting that needs to be changed by me or another admin so I see the 'delete' option? Or is there another fix?
Check the Permission Scheme for that under Issues.
This is what is showing for the permission scheme under Issues. Should I change these? If so, to what?
Dan - are you an Administrator on the project? The screen print shows that only Administrators on the project have Delete - not System Administrators.
See my screen shot here - that is what it should look like for System Administrators to be able to Delete.
