Deleted 1 obsolete rows
Christos Moysiadis
October 2, 2018
Until Jira Soft. 7.11 i didn't notice this log!
After the upgrade to 7.12 this is coming more often!!!
2018-10-02 15:16:45,356 JiraTaskExectionThread-1 INFO admin 904x77x2 kk0uig 0:0:0:0:0:0:0:1 /secure/admin/jira/IndexReIndex.jspa [c.a.j.p.d.p.source.cache.ObsoleteRowRemover] Deleted 1 obsolete rows
Except this i decided to make a re-index..... and while its running i have this screen in terminal...obsolete.png
What is this all about! i cant find info!
thnx in advance
CM
Andy Heinzer
October 3, 2018
I dug into the source code of Jira to find the ObsoleteRowRemover.java and found this comment in the file to explain its function:
 * Removes the obsolete row based on updated column. If for a unique combination of issue id and provider key, there are
 * multiple rows, it removes the older one and returns the latest one.
In turn, since you are seeing this message it would appear that the code found multiple entries that had the same issue id and key.
I would not be concerned to see this message, this is an INFO level message so the nature of this message is not really a warning or an error.
Christos Moysiadis
October 3, 2018
@Andy Heinzer thnx a lot for your time and for the link to source ;) :D
