Deleting original key from a moved isse
Mike Rolls April 5, 2022
After moving an issue is it possible to delete the reference to the original key reference by deleting the entry from the 'moved_issue_key' table?
Mike
Fabio Racobaldo _Herzum_
Hi @Mike Rolls ,
technically you can do that. That table keep mapping between the old key and the new issue object so, if you delete it you will delete the old reference.
Btw, I don't understand why you should that considering that this operation could have impacts like :
  • Reference in comments, description or in other text field or URL field could not work anymore
  • Filters based on issue keys (if existing) could not work anymore
  • Links in Confluence pages could be impacted
Hope this helps,
Fabio
Register today
