One of our team member left the company. IN Jira he got assigned many issues. What should i do with this user? if i delete him (that is the only option i see) what happens to those issue. Does they get assigned to default user (in our case that is Admin).
pl guide me.
-Bala
The usual advice is to remove the user from all their groups and roles. The most important things this will do are:
You won't be able to delete the user completely unless you re-assign all their issues to someone else (or unassign them). Most of the time, people don't bother - making a user inactive as above is enough, although it's well worth running a filter for "assignee = ex-user and resolution = unresolved", so you can scan their outstanding work and get it assigned to someone else.
Bala,
If you remove that user's access rights without deleting the account, you may want to check the email address assigned to it, because accounts without group membership will still get email notifications. So depending on the settings of their Jira profile, your ex-teammate might actually keep on getting updates from your issues. Just a heads-up :)
