Sign up Log in
Depends UpOn Value selected in Custom Field get Notification
Kumar
October 24, 2018 edited
Hi Team,
Here i'm creating a notification Scheme so in that one of my requirement is I have a field called "Group"(group picker)  and I have groups in jira  "X,Y,Z " .
 I need only when user select particular group in the field while creating the ticket only that group members has to get notification
if i select other groups in that field they don't want notification.
example:
I'm creating a ticket I selected "X" in the Group Picker field that group members has to get notification . if I select "Y or Z" for those groups don't required notification
can you please provide the script to achieve this
Thank,
Kumar
Kumar
Neta Elyakim
November 6, 2018
You can do it in by the notification scheme.
Go to your project setting > edit the notification for "Issue Created (System)" > select "Group Custom Field Value" and select your relevant "Group" custom field.
If you want that only this group will get the notification about the issue creating, you need to remove the others roles that get the notification.
For example in my Jira, those are the Notifications for create issue event:
  • Current Assignee (Delete)
  • Reporter (Delete)
  • All Watchers (Delete)
Then you just need to click on delete and add only the group.
You can apply it to the Update event too (or every other event that you want)
Let me know if it solves your problem.
Kumar
November 6, 2018
HI @Neta Elyakim thanks for your responce the thing is those 3 groups will create tickets in jira but only that particular group need notification only that particular group when they create tickets.
As you suggested if i do that they will get notification for every ticket even though the ticket is not from that group.
In notification scheme I have option to add that particular customfield to get notifiy but in that I need only when the ticket created with the Group "X" created ticket only for those tickets they want notification.
Can you please suggest regards this.
kumar
Neta Elyakim
November 6, 2018 edited
So, you can send a custom email with script runner- post function, on create transition:
Go to your relevant workflow > post functions > Send a custom email and you can use this guide-
https://scriptrunner.adaptavist.com/5.4.12/jira/builtin-scripts.html#_send_a_custom_email
Set the condition only if the group equal ABC.
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
