Deprecated Power Database Fields types
Batuhan ŞEN July 6, 2022
Hi everyone,
Some Power Database Custom Fields will be Deprecated.
A warning like that:
You are using old field types provided by Power Database Fields, which are now deprecated. We recommend using the new Advanced Database Row Field.
I can add a new field but there are lots of fields like that.  Is there any easiest way like transformation or something else?
Could u help me? or Any suggestion for this circumstance?
Thanks a lot.
BR
Mohamed Benziane
There is a migration tool in the administration tab of the plugin. Did you tried it ?
