×Hi,
Is there a way to add a default text (template) to the issue description field so that colleagues who create the issues can use it and not write a design brief for each issue?
I am asking for a company-managed project.
Hello @Ivan Grudev
Jira Cloud does not natively provide the ability to create template text for the Description field in Company Managed projects.
You could achieve that requirement using a third party app - Adaptavist's Behaviours app provides that capability.
Note that while that app is free, a prerequisite to use it is the Adaptavist ScriptRunner app, which is not free.
Alternately there is a work around that uses a custom field and Automation Rules that relies only on native Jira functionality. That work around is described here:
thanks for the detailed answer! :)
