I designed a screen with a small number of attributes. However, when I view the screen, I see other attributes, like Original Estimate, in addition to those I included.
Would it be possible to restrict the latter fields to show?
Thank you.
Can you share some more context and screenshots of the screen.
If you create a screen only the fields you provide are on the screen, not fields you didn't place on it.
What actions did you take?
This is the screen I designed.
This is what is being viewed.
Thank you.
the screen is fine the options in the side panel are related to the issue layout.
Select the configure option (next to the date information).
Adjust the layout of your issue as you desire.
