Determine in Groovy if issue was created via Crucible or Bamboo?
Nathan Nantais January 26, 2016
We have a validator that prevents us from creating new issues unless a specific custom field is set. The problem is when issues are created from Crucible or Bamboo, there is no way for the user to set the custom field.
I would like to use a Groovy 'custom script validator' (via ScriptRunner) to allow the issue to be created if the source is Crucible or Bamboo. Is there any property of the issue that can tell me that the source of the issue creation was from outside JIRA, or specifically from Bamboo or Crucible?
Thanks.
import com.opensymphony.workflow.InvalidInputException
import com.atlassian.jira.issue.label.Label
log.setLevel(org.apache.log4j.Level.INFO)
log.info("Create issue Customer field validator");
Issue myIssue = issue;
def customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField myCfField = customFieldManager.getCustomFieldObjectByName("Customer");
Set<Label> myCfValue = (Set<Label>)myIssue.getCustomFieldValue(myCfField);
// Check that customer is set
if (type == 'Sub-task') {
    log.info("Issue type was Sub-task. We don't care if Customer is set.");
// TODO - allow the issue to be created if the source is Bamboo or Customer
else if (ISSUE WAS CREATED IN BAMBOO OR CRUCIBLE) {
 log.info("Issue was created in Bamboo or Crucible. We don't care if Customer is set.");
else if (myCfValue != null && myCfValue.size() > 0) {
    log.info("There are " + myCfValue.size() + " labels present in Customer.");
else if (myCfValue == null) {
    log.info("Customer was null.");
	invalidInputException = new InvalidInputException("You must select a Customer.")
else {
    log.info("Customer had 0 values.");
JamieA
January 26, 2016
I think both cru and bam will create the issue via REST? Although I'm not sure about that, they might use something like the Issue Collector.
You could see if
webwork.action.ActionContext.getRequest()
is empty... if so it's being created via rest (I guess) so allow it.
You could also look at Thread.currentThread().stackTrace... and see what the difference is between the different ways of creating an issue. Super hacky though.
Nathan Nantais January 28, 2016
It seemed to work. If webwork.action.ActionContext.getRequest() is null, it indicated that the request came from Bamboo. Thanks!
Are there other objects besides 'issue' available for me to inspect in the groovy script?
Yes, @Thanos Batagiannis [Adaptavist] that was my hope as well. I logged a few different pieces of information to see if any of them were interesting:
issue.getIssueType().getName(): Sub-task
issue.getCreator().getName(): NULL
issue.getReporter().getName(): "jdoe"
issue.getReporterUser().getName(): "jdoe"
issue.getEnvironment(): NULL
January 26, 2016
hmm ok, so checking the reporter or the creator won't work (I was thinking loudly trying to find a field in the issue that will tell if the issue created via bamboo)
@Thanos Batagiannis [Adaptavist], when created from Bamboo, issue.getCreator().getName() is the username, e.g. "jdoe". I haven't tried creating one from Crucible today.
January 26, 2016
So when the issues are created via bamboo or crucible what is the value of the reporter field ?
Let's build A Rovo Agent 🤖
Save your spot
