Developer/Staging Environments with Jira Cloud
Mark Anderson
Hi All
how do I go about having a developer/staging environment with the cloud version? I need a place to create and test workflows, etc. and then need to deploy to cloud
Regards
mark
Peter T
June 18, 2016
Hi Mark,
lets say you got a test and staging environment in the Cloud somehow (the only option I can think of are two 10users/10$ instances), how are you planning to move once created workflows, fields and screens to the production?
Mark Anderson
June 19, 2016
My point exactly. Seems I can only export and import between projects on same instance
Like Jorge Colon likes this
Peter T
June 19, 2016
Out-of-the-box JIRA does not provide any capabilities to migrate configuration. There are several add-ons that fit into that niche for example - Configuration Manager for JIRA is the top add-on in the area.
Unfortunately non of the add-ons work for the cloud due to the technical difference of the cloud platform compared to the on-premise.
This is one of the reasons some people prefer the on-premise or other cloud solutions.
So unfortunately the answer of your question is - no, it is not possible.
Peter T
Omid H_ October 28, 2019
Is there any option right now to make a full clone of our Jira Cloud existing Production to Jira Dev Cloud (to have the same workflows, configurations, fields ). If yes, how it works?
Peter T
October 28, 2019
Hi Omid,
at this point there is no other options than the described above. We at Botron are actively working on Configuration Manager for JIRA cloud that will make creating a Testing/Staging environment a breeze.
Watch our marketplace page for updates:
https://marketplace.atlassian.com/apps/1211611/configuration-manager-for-jira?hosting=server&tab=overview
Peter T
Greg Tripp
June 29, 2021
Thanks Peter. I think there is definitely interest in a Configuration Manager for Cloud. Please keep us posted.
Mark Anderson
June 20, 2016
thanks. i though I read somewhere you get an automatic dev license with a cloud account. (0 day expiry is useless for an production app
Corentin Méhat
June 20, 2016
found here :https://www.atlassian.com/licensing/purchase-licensing#licensing-7
"Developer licenses are available to existing commercial, academic, and select Starter license holders (not available for cloud products) who wish to deploy non-production installations for use in testing and development of the Atlassian software (e.g. version upgrades, customizations to the software, etc) that should not be done on a live production instance."
Corentin Méhat
June 20, 2016
it's not a permanent option, but you can export your data from your cloud instance and import them in a server install with an evaluation license (valid for 30 days, extendable to 90). The procedure for the migration is explained here : "Migrating from JIRA Cloud to Server applications".
Another option is to create a new "JIRA on demand" cloud instance also with an evaluation license, but in this case it's only available for 7 days (cf. "Can I evaluate a product for free before purchasing it?" ), following this procedure "How to migrate projects from one JIRA Cloud application to another" .
Best regards,
cm.
