Difference between Due Date and End Date
Vera Bakshaeva
Hello!
Could you please help me to understand, what is the difference between end date and due date?
In Internet I have found, that due date  - is the time something should be delivered,
end date - is the time something must be done.
Is it right?
Best regards,
Vera Bakshaeva
3 accepted
3 votes
Stan March 27, 2020
Most common use case:
Due date is a desired date requested by initiator (e.g. project team requests to execute something by x due date)
and
End date (which can be Target End, End Date, Baseline end date or other end date) is a date by when task will be completed and this is defined by an executor (e.g. to execute it it will take longer hence End date will have different date)
Sundara Rao Damaraju June 23, 2020
After end date there will not be any delivery.
Due date is an intermediate milestone date. Suppose there is an epic to be completed by 31st October and will be starting on 1st July.
Here end date is 31st October.
Due date1 : 1st Milestone elaboration to be completed by 30th July.
Due date2 : 2nd Milestone development to be completed by 30th Aug
Due date3 :  3rd Milestone,  acceptance testing to be completed by 15th October.
Due date4 and end date : 31st October--> Launching to be done on this date.
Vera Bakshaeva
Sandra, thank you very much for your so clear answer!
Like • 5 people like this
PVS
Banned
November 22, 2019
HI @Vera Bakshaeva
Due date is a built-in field, "due date" - it's up to you to decide what it means in the context of your processes.
It's Right Man
end date - is the time something must be done Issue.
PVS
Vera Bakshaeva
Hi @PVS
Thank you very much.
Best regards,
Vera Bakshaeva
Like • PVS likes this
Help us plant more trees
